P Prodjay10 Member Nov 1, 2021 #1 Windows roll down. Shell 2 comes up an inch or so and stops. I get an error a68c. Not sure where the switch is located. I found a link to a pdf but it’s broken. Also how do you manually open close the top?
F flybobbie Elite Stourbridge Nov 1, 2021 #2 Welcome to the club, we should have a pin and tie just like those pilots that have ejected. Probably broken wire, just search the forum. https://z4-forum.com/forum/viewtopic.php?t=131864
S Smartbear Lifer a barn in Somerset Nov 3, 2021 #4 Prodjay10 said: Anyone know how to manually open the roof? Click to expand... You need to open the brass valves on the pump. Rob
S Smartbear Lifer a barn in Somerset Nov 3, 2021 #6 Prodjay10 said: Will that unlock shell 2? Click to expand... You said that she’ll 2 already comes up a couple of inches, so it must be unlocking ok. Rob
P Prodjay10 Member Nov 4, 2021 #8 I have found quite a bit of info on the line but nothing on opening the top manually. Anyone know where I can source some fine stranded wire to fix the broken wires?
