E89 rear light cluster.
Phoenixboy
 english riviera
Passenger side rear light cluster.
Just been removed from my E89
There was a minimal amount of moisture ingress, but didn’t seem to get any worse for the last 12 months since I noticed it.
Replaced mainly as I’d had a new one fitted on the other side, so decided to bite the bullet and replace it.
No fault codes were coming up, so I assume it was minimal moisture, and not sufficient to get into the led.
If it’s useful to someone, will let it go for £60.00 posted in the U.K. only.
Just to add, this light was only removed last weekend, and is fully functional with no issues on the indicator strip, which is usually where the problems are.
Argyll Andy said:
Zforbes said:
Phoenixboy said:
Bump for a bargain 😀
PM'd you
This the next step in solving the central locking issue :poke: :rofl:
This is the next step for removing water from my rear light :driving: :rofl: :rofl:
The central locking is fixed. 9 days without fault for something that occurred daily for a few months. Problem is all I did was strip things and put it back together so not sure what it was.
These cars are certainly good at keeping me busy. Still wouldn't swap it for anything of a similar value though. :thumbsup:
