A
Anonymous
Guest
Owdgit said:Don't know if it's just delaying the inevitable or a battery anomaly but after going for a good ride and an engine restart the steering warning has gone and it seems to be ok.
As unlucky Alf says "it's probably just a matter of time "
If you follow your signature I would suggest you drive it a few times in the next few days...
Battery failure causes all sorts of both permanent and transient failures..
In the world of computing you can never ever reboot a computer enough times to see if you can reset it..
With 30 ECU’ s on board an E89 and the amount of interdependence of sensors and ECU’ s it’s worth a try along with a new battery and battery registration..
Probably 85% of all errors related to battery failure do reset themselves..sometimes you need to clear the codes and then drive and repeat..
You can lookup your vin to see if you were an unlucky one with a batch of duff steering systems ...I suspect your car is in the relevant age range..
