E89 Paddles and "S" mode not working
Steve66
New member
Hi all,
I have tried the paddle wire switch mentioned on this forum to alter the left paddle wiring (switch 2 outer wire) to make the paddles work more like normal car paddles ie different each side when you pull the paddles.
The problem I now have is the paddles don't work at all and if I move the gear change to the left the car does not go into "S" mode.
Gearbox will still go into sport by the swtich next to the lever
I have tried swapping the wires back and still no look
I have read the codes and there is an error on the gearbox. If I clear it it just comes straight back
Any ideas please
Car is a 2.3i sdrive auto
Thanks Steve
Try disconnecting the battery might reset it.....
Also on your photo we cannot read the entire entry on the right (5087 EGS) which is the one we need to see
