domsz4 said:
Yorkie Z said:
The Guy sticking the M5 V10 said that the electrics is relatively straightforward.!! He's doing an amazing job on his, you should pick his brains.
Great project, the forum needs people who push the boundaries
ill stick my neck out on this one and im happy to be corrected as its something i dont really know about.
does the engine run on its own ecu? by this i mean its not just 1 big box where all the wires go and control everything from the radio to the ignition. i was under the impression that many systems have their own ecu. so if this is the case and you can "run" the rest of the car without the engine ecu then controlling an engine with an aftermarket ECU shouldn't be too much of a problem. the likes of omex/emerald/dta etc do this. i guess items like the speedo/ rev counter etc may be an issue maybe?
Just copied this off the other thread. I was asking Steve about fitting a V8 into the Z..
Yorkie Z wrote:
Hi Steve
Awesome project mate.
Is fitting a different motor into the car an absolute wiring nightmare.?? I've been looking at Bmw V8 engines on eBay wondering "daydreaming" if it would be a good idea for the z.
From Steve....
Seems fitting a supercharger to the 3.0 costs 3k, so a 2.5k V8 sounds a lot more fun. Part of me has a burning desire to have a V8 car :evil: :evil:
Thanks Yorkie.
The supercharger route is well proven and fairly pain free. Dropping in a whole new engine not designed for the vehicle is a minefield that's certainly had me scratching my head numerous times. The wiring for my project has turned out to be one of the simpler areas, thanks to Specialist Components excellent ecu they have configured to suit S65/S85 engines. There's a maximum of 14 wires to tie into the chassis loom, I've actually only have 12 to do to make it run. Two thirds of your 3k supercharger would be spent on the ecu and engine loom.
The tricky part is making the drive train fit with new engine crossmember, steering rack/column, engine mounts, clutch, gearbox mount, custom exhaust, new oil cooler setup, dip stick, complete new fuel system, radiator setup, induction, and the list is still growing.
I've had a quick tally up of my hrs and 500 wouldn't be unrealistic, if not more. Times that by £45 and I'm well shocked at a possible labour cost for something similar, as for parts including 6k for the car I'm sitting at £18,500.
So Yorkie V8 would be a very interesting car and in my opinion easier to install, it'll still be very costly.
