I have just picked up 4 No. replacement spark plugs from Berry’s of Croydon. Can anyone tell me the correct gap for NKG R5 M2XE or are the pre-gapped? Also can you confirm the torque setting.
All should be written on the boxes.
They are tricky to find but should be there.
Should be pre-gapped but best to check.
Torque is something like 12nm from memory (but check on the box).
I think RBM in Hook can do roofs, but not sure. They are very well respected on here for servicing/ repairs.
If it is a bootlid microswitch needs changing, then if you can change plugs, you can change those!
There is a huge amount of info regarding roof faults on here.
