clarker63 said:Its a pain in the butt. probably the worst fuse box you'll ever come across.. Once you've undone the nut it slides out on an extension thing...
Fortunately moving it doesn't appear to disconnect anything but the first time you take it out you'll wonder what the designer was thinking! good luck!![]()
could be.. you need to get your head right under the dash and use a bright torch.. much harder than you would expect!Silverstar said:I've heard about it sliding out on an extension. This afternoon I hardwired a dash cam to the fuse box but for whatever reason it wouldn't slide out, I could only push it down. Does it slide out on the extension easily? seems like there are whole bunch of cables underneath that might be stopping it.
RobbiZ4 said:On elder E89 there is a central screw, on newer Z4 there is the white wing to be opened. At first, the block should be pressed down for 5-10cm, then pulled towards the seat.
There is nothing else to unlock, but on the first time you should pull harder.
clarker63 said:could be.. you need to get your head right under the dash and use a bright torch.. much harder than you would expect!Silverstar said:I've heard about it sliding out on an extension. This afternoon I hardwired a dash cam to the fuse box but for whatever reason it wouldn't slide out, I could only push it down. Does it slide out on the extension easily? seems like there are whole bunch of cables underneath that might be stopping it.
Well, interesting.Silverstar said:Mine is a 2009 model and it only has the wing nut...
did it work though?!Silverstar said:LOL I did just that turned myself upside down and used a 1000 lumens head torch, didn't think my body would contort so much at my age! Might explain the pains afterwards.
clarker63 said:did it work though?!Silverstar said:LOL I did just that turned myself upside down and used a 1000 lumens head torch, didn't think my body would contort so much at my age! Might explain the pains afterwards.
Oh dear ! At least you got your camera working thoughSilverstar said:Nope
