E89 - Drivers size window buttons broken
Any suggestions as to how to fix this? It seems like it is not the window motor, not a fuse, not wiring loom fault, and not the central locking unit which I have seen suggested in other forum posts. Do I need a new button unit? Is it s software fault? Is it a sensor thing?
- The drivers side window buttons have stopped working. There are 5 window buttons on the drivers side door, none of them do anything.
- All the windows still work fine when putting the roof up and down.
- The door windows still drop a few mm to clear the seals when opening the doors and go back up after closing.
- The passenger side window button (on the passenger door) also still works fine.
- The mirror controls still work fine.
- As far as I can tell, the central locking still works fine.
