@f_cking.cooper said:Dinan upgrades do not effect your BMW new car warranty when installed through a bmw service dept, and Dinan provides a warranty on top.
That`s good news
@f_cking.cooper said:Piston #3 missing??
Hi and welcome to the forumbilldun said:Hi all. As well as reporting the faults listed and warning owners to keep checking their boot seals, I am looking for some advice on how I might pursue a complaint against the dealer for replacing a part I don't believe needed to be replaced.
1. E89 sDrive 23i
2. 2010/60
3. White
4. Red
2015 (April)
5a. Parking brake light constantly illuminated (yellow).
5b. Resolved
5c. Total bill/cost to me £199 – diagnostics and installed new software.
5d. This fault appears to be something to do with incorrect response to battery voltage dropping. Tried pointing out to them that software does not suddenly go wrong and fault must have been present from manufacture. Guess where that got me.
2016 (May)
5a. Roof opened half way and then stopped and would neither open or close.
5d. Resolved (but not to my satisfaction – see below)
5c. Total bill/cost to me £2038 New hydraulic unit and wiring/hydraulic line harness. New boot seal and vents.
5d. Problem caused by water ingress through boot seals. First video from service department showed external corrosion of hydraulic unit and severe corrosion of an electrical connector block. Second video showed that hydraulic unit had been replaced and explained that the connector was not available separately and would require the supply of a complete wiring/hydraulic harness in order to obtain the connector to splice into my harness. I asked for the replaced items to be returned to me. On checking the hydro unit it certainly showed some external corrosion but on removing the outer cover of the motor it was obvious that there had been no significant water ingress and on connecting a power supply the motor worked perfectly. It is obvious that they could not have tested the unit as they had already replaced it before repairing the corroded connector. I am really annoyed that they have replaced a very expensive part without checking if it was serviceable or not. I spoke to the Service Manager who, when he realised they had replaced the part without testing the old one, fobbed me off with “it's our experience that they fail eventually if they have come into contact with water” ignoring the pictures I sent him showing that no water had got into the unit.
1. E89 sDrive 23i
2. 2010/60
3. White
4. Red
2015 (April)
2016 (May)
DrChef said:1. E89 Model 20i MSport
2. Year / Reg: 2012
3. Colour exterior: Alpine White
4. Colour interior: Black
5a. Issue description: 12V socket not working
5b. Current status: Unresolved
5c. Warranty Claim: none
5d. Comments: still under investigation. Both sockets (dash + armrest compartment) not working
mr wilks said:DrChef said:1. E89 Model 20i MSport
2. Year / Reg: 2012
Is that even worth paying the excess ? :? could a decent indy or auto electrician not have sorted that easier & cheaper :?
There seems to be a sub text that the 35i and 35is are likely to cause an owner quite a bit of cash at some point in their lives, maybe more than once?mr wilks said:So 5 yrs into this thread & remove cracked wheels + annoying rattles it doesn't make too bad a read for current 89ers or potential 89ers![]()
There is the vein running through of main dealers appearing clueless or changing parts out for no good reasonmore proof that if running any BMW out of warranty a competent & trusted indy should be highly prized :wink:
