e89 Carly fault codes - what to worry about?
Nekh
New member
Hi all,
I have recently purchased a 2010 e89 and I'm loving it! The only issue was a roof warning light, which with the help of this forum I suspected was a hall sensor problem. I ran a diagnostics report with the Carly app just to double check and I got 11 faults - I am wondering how much to worry about this! Should a car have 0 faults? Or is it natural to have some faults which you can ignore?
Here are the faults:
ABS / DSC / Brake
Dynamische Stabilitaets Kontrolle / DSC
Fault Code: 005F1C
Fault Explanation: :internal control unit: 1V5 supply voltage error /
Drehzahlfuehler rear right power or signal quality / Info entry: Active
braking intervention at overheated brake discs. / Info entry: Active
braking intervention at overheated brake discs --- (DSC: brake disc
temperature briefly inflated) / Info entry: CUS: Active brake
intervention while overheated brake discs.
Fault Code: 005EAC
Fault Explanation: :Speed sensor, front right line fault / Yaw-rate
sensor: - platform software (PSW) - suspected error DRS. / Yaw-rate
sensor: platform software (PSW) - suspected error DRS. / Yaw-rate
sensor: platform software (PSW) - suspected error DRS --- (DSC: DSC
sensor: plausibility)
Fault Code: 005E96
Fault Explanation: :internal control unit: Dynamic ROM Check Error:
M3 / (DSC sensor: plausibility DSC): - lateral acceleration sensor error
suspicion --- platform software (PSW) / Lateral acceleration sensor: -
platform software (PSW) - suspected error. / Lateral acceleration
sensor: platform software (PSW) - suspected error.
Instrument cluster
Instrument cluster / Kombiinstrument
Fault Code: 00A559
Fault Explanation: :Klemme30g f shutdown / KL30g f shutdown /
KL.30g f shutdown / KL30g f Cutoff
Heating / AC
Air conditioning / Klimaanlage
Fault Code: 009C48
Fault Explanation: :Mixing air flap (LIN) / Mixed air damper left (LIN)
/ Warm air motor left / Warm air damper motor Left motor address
11hex / Mixed air links / Motor inside / outside air links / motor
defrosting
Body
Fussraummodul /FRM
Fault Code: 00A8B7
Fault Explanation: :Stoplight right defective, PL3 from 07.14 and
SA5A1: fog lights LED defective, PL3 from 07.14 and SA896: daytime
running lights Halogen right defective
Other
Cabrio-Top-Modul E89
Fault Code: 00A698
Fault Explanation: :Hall sensor VSW10 / Koppel shutter open /
Temperature sensor of the pressure pump / Convertible top lid open
Fault Code: 00A69E
Fault Explanation: :Speed too high / @ / valve V5 / valve F2 / Relay
RPS pump rod / Relay pump RP1
Fault Code: 00A6A4
Fault Explanation: :supply limit sensors / Exceeding of the speed /
Control buttons / Hubdach / @ / Top connector removed
Fault Code: 00A690
Fault Explanation: :Rotary encoder main column / Hall sensor
VSW5.1 / Hall sensor placed VSW2.2 main column / Hall sensor
VSW4.2 / Hall sensor VSW4.1 / @@
Fault Code: 00A694
Fault Explanation: :Hall sensor VSW6.2 / Hall sensor VSW8 / Hall
sensor VSW6.3 / Micro switch SW HUNT (MS12) shelf below / Hall
sensor VSW6.1 / Supply rotary encoder / Hall sensor VSW1.2
convertible top lid open
Any advice would be most appreciated!
Thanks,
Neel
Hi Neel
As you have recently purchased the car, and don’t know what may have been addressed but not cleared, it might be an idea to write all of the codes and info down before clearing them and seeing which ones come back before delving too deep into sorting them out.
loolz, he kinda did that already :roll: good idea tho
That's quite a mixed bag OP!
If you haven't already cleared those codes I'd suggest that would be your first option.
I find that if I disconnect the battery on my E85 for any length of time, then reconnect and do a scan that I get all sorts of spurious looking codes that were not there before. If you've just bought it and it's been sitting on a garage forecourt or such for any length of time with a slowly degrading battery this creates a risk for dodgy codes in my experieince.
The last time I did it after the car was standing for 2 months I got codes for misfire on 2 cylinders, which I never had before. But getting the battery back up to tiptop condition then scanning again brought back the handful of codes that have been there for a while.
You don't normally want to see any trouble codes. Agree that it makes sense to clear these first, then see after about a week of driving which are back. Some likely will as your description lists their status as 'present'. The ones about the defective lights are easy enough to check. My guess is you have two or three bad sensors and/or wiring connections.
I just got my car myself last week and, after scanning with the Foxwell 520, found three codes, none present. I expect they won't return. Depending on the problem, you may decide fixing some is not necessary.
Wow, thanks for the quick responses!
Clearing the codes sounds like a smart idea - Given that my lights seem fine I have a feeling these are old codes, possibly due to a disconnected battery or something similar.
I will let you all know how it goes - cheers for the help!
Neel
When my roof went faulty had a load of hall sensor error codes, non were faulty, it was a pump motor relay fault. Also some abs, never had any problems. Perhaps when changing brake pads it threw up some codes and as you say disconnecting the battery.
I cancelled all mine and will check again in a few months.
I have the Foxwell 520, seems it can store data and hopefully save to computer.
Hi, frankly if that was all the codes generated for some time then it’s not that bad...I find that you get random/spurious errors over time..I’ve cleared probably 15 fault codes when I got Carly...I check every now and again and I get the occasional soft error popping up..the problem with ECU logging is it does seem to generate large number of usually temporary errors..
A lot of your errors seem to come from abusing the roof mechanism/light bulbs..
As the others have said best thing is to note them down, clear them, then monitor for any that regularly return...
The ECU works out what the serious errors are and generates a fault light on the dash display..
All IMHO
