SO8 said:R.E92 said:Well since my last post in this thread I went ahead and did an ECU remap. I did consider a piggyback unit but decided against it (I won't bore you with the details)
The stock power output is fine for a while but I'll always want more power :evil:
Went with the OpenFlash tablet from Procede Tuning. Worked out about £300 after shipping and taxes.
There are only two real options when it comes to ECU remaps with the n54 and both are US based. Cobb or Procede.
The Cobb unit is a fair bit more expensive and the guy behind Procede is called Shiv who is the godfather of n54 tuning so I decided to go with Procede.
I haven't yet been for a dyno but the map itself is working brilliantly. The logging function of the OpenFlash means you can see the timing advance, fuel trim and boost pressure to gauge the health of the tune.
It's holding 15psi with no fuel trim issues. I've compared it to logs from similar Cobb maps and it seems a lot smoother.
A few US posters at bimmerpost have done dyno runs with the Stage1 flash and have reported around 340-360 horsepower and the wheels. Which is 391-414HP at the crank. That's around the sort of figures people are getting from Cobb and the JB4 piggyback unit.
It certainly pulls a lot harder and with the DCT you very quickly end up doing stupid speeds. It's so smooth in delivery that you don't really appreciate it until you watch how fast the speedo moves!
Is it actually that easy to put the power down in the dry though ? is 1st now useless ? I am guessing 2nd upwards is epic but just how much does the traction control stop the power ?
First gear was useless before the remap. Hell first gear was useless in me 320d with a planted foot!
Third is where traction becomes less of an issue but the car is currently on some mid range junk tyres. Once I've got the PSS tyres that are sat in my garage fitted it will be stuck to the road a little better.
It's not all about planted foot speed gains though. The car just feels like it has more grunt in normal driving.
Regarding the remap to the 35is. I don't think the engine will map any higher at stage 1 than a 35i. The 35is has an uprated cooling system but no physical changes to the engine.
You might be able to skip installing additional cooling if you were to go for a stage 2 or 3 setup but you would still need to change the intake and exhaust to get any more from the engine.
The 35is gains it's extra power from the overboost function. Basically allowing slightly more boost for a short duration. If you remap the car they will just remove the overboost code and just let the boost max out permanently at 14-15psi.
