junglie said:I can take some expenditure but don’t want a money put!
B21 said:junglie said:I can take some expenditure but don’t want a money put!
Failed water pump..highly probable …£1k fitted
Single turbo failure £2k fitted
Waste gate failure £2k fitted
Two turbo refresh £3k fitted
Turbo oil leak £1k fitted
Cam box failure £700 fitted
Coils £400 fitted
Second injector failure ..possible…£400 per injector
Inlet port coking £350
All Indy prices
Lynchy said:I think we need 35i and 35is owners to step forward to say what big spend they’ve had instead of people saying what could go wrong. I have had 2 35i’s albeit for a short time and they’ve been brilliant. The same kind of scaremongering goes on with the Z4M as well and yet I had one for 8 years and again it was brilliant for me and I regretted selling it and that’s why I have just bought another one. I also have a quite a few friends that own a Z4M and they’ve been faultless for them as well. There will always be a horror story and that could be down to poor maintenance or how well a car has been looked after.
Lynchy said:Thanks Andy, I’ve heard the adaptive shocks can be expensive, when they go wrong is it usually down to mileage or are they just not great. Dealer prices don’t help as labour is very expensive.
You never know for sure whether the dealers are being truthful or not and Labour charges are extortionate in my opinion.Glad I have the MSport suspension although I can imagine the adaptive is much better.Argyll Andy said:Lynchy said:Thanks Andy, I’ve heard the adaptive shocks can be expensive, when they go wrong is it usually down to mileage or are they just not great. Dealer prices don’t help as labour is very expensive.
Ed, I think they were about £1300 a corner by the time labour was in and mine had 3 replaced. All done between 30-40k I think. IMHO a bit of a scam, as soon as the dealers knew it was under warranty and being MOT,d, a light misting of oil seemed to be all that was needed, as far as I’m aware none of them failed but outwith my ownership so can’t 100% confirm. The gearbox wiring and module wouldn’t apply to this car as mine was a DCT. It also appeared to be a “freak” fault as the dealer had never had one before so not a regular/routine weak spot as far as I knew
That doesn’t seem too bad, I was very much interested in your VO Zed last summertiglon said:35is for nearly 4 years and over 30k miles. Lightly remapped and driven often enough and fast enough. Always allowed to warm up before exceeding 3,000 revs and oil changed approx every 7k miles or so. 2014 model, and I suspect the later N54 ancilliary parts were perhaps better made than the earlier ones.
Water pump replaced for about £1500 at something like 76k miles, but it hadn't failed there was just a shadow error code that has, on other forums, been identified as a precursor to water pump failure so I replaced & upgraded it as a precaution.
Rocker cover gasket replaced for £600, but I think, in hindsight having seen the gasket that came off, that was a case of spilt oil and auto-hypochondria on my part.
And... that's it I think. Oh, I replaced a few coils, but they're what £30 each? And generally you can fit them yourself in a few minutes. Same with spark plugs.
The 4th damper/shock that wasn't replaced under warranty earlier in life was still going strong with no oil misting and no problems. If these do go, surely it's just an excuse to upgrade all 4 corners to B12 for under a grand? Your local dealer are only getting thousands to replace these if it's still under warranty.
No HPFP issues, no turbo issues, no roof issues (apart from that time I got my t-shirt caught in it while closing but I can't blame the car for that). Never broke down or left me stranded. If I'd had a warranty at £600 per year (they definitely aren't £600 any more though), I would have lost money on it.
Add in depreciation of just £6k over those years and mileage and, given the power etc, I'd say that's a fairly good proposition.
I wouldn't like to calculate what I spent on tyres and fuel (or modifications!), but that's a different matter. A 30i isn't going to have drastically lower costs on those two things anyway.
All that said, I wouldn't buy a 35is or 35i if the prospect of a £1k-2k+ bill terrifies you. It's part of the deal on a car of that age with that level of performance. Also worth bearing in mind that BMW maintenance costs are a lot higher than many other brands. That same water pump & belt job on my Yeti was a third of the price.
A friend of a friend had a very sensible, mainstream, cheap to run 2014 Mini Countryman Cooper SD from new and a few years ago, on 55k miles and after 10k services etc, needed a new engine costing £9k outside of warranty. Pick any car, any engine, I'll find you a load of horror stories about it on google.
