_Paclunch
Does anyone have two rear brake callipers I could, borrow, buy, or know where I can get some?
This is for the Z4M, I've scoured the web and they basically don't exist, I've even searched for E46 CSL thinking something might come up.
The only ones that do appear are on Ebay and the guy is selling a whole front and rear set for 3K.... they don't have to be OME, just anything that'll fit.
I've already had to return a set as the part numbers were wrong
I want to refurb my rear brakes, but as its my daily I cant be without a car, and rushing a brake job is just asking for trouble.
Back story:
Note: This is my first RWD car.
Under heavy braking my rear left wheel will lock, at first I thought I had downshifted and didn't rev match properly. Tipped into a left hander and then the wheel locked and dragged. Just assumed it was driver error.
Then I went for a drive down the lanes and something felt a little odd, so I hit the brakes in a straight line and it locked again. Then I noticed a squeaking noise. Now i'm thinking its a sticky calliper.
I replace the guide pins (they were corroded) and rubber boots and went for another drive and did the same manoeuvre, and it still locked the rear left. Now its likely a full refurb with the piston out.
Bought a set on Ebay with part numbers that matched, but they were for the normal Z4 so i've had to return them. Although when I had the brakes off I pushed the piston back and forth a few times to try and loosen it up. Squeaking has gone for now, but its only a temporary fix.
Would love a set of AP's, but ££££. One day.
Back story:
