E86 with Koni Sport and -35mm springs
So you've decided against the Koni..?
I can recommend if you need any encouragement? :rofl:
Recently another member had a passenger ride in my Koni equipped coupe with Eibach/MSport, and he said it felt better than his stock SE height Roadster.
My issue isn't with the Koni set up but ride height and scrapes/speed bumps. I need the car to be as practical as possible as speed bumps are common where I live. I don't want to limit where I can/cannot drive my car.
If you are happy to demonstrate your car so I can get a ride in it with you then I’d be up for that :thumbsup:
It's not the dampers that sacrifice ride height, it's the springs.
HR are low, Eibach Pro not so much, Msport a little higher, and SE is high.
I'd say Msport height should do you to be safe, but tricky to guarantee without knowing your roads in detail.
I can recommend Koni as I run them and they feel fantastic with a mix of Eibach and Msport spring rates, also based on feedback from an SE owner with 17" wheels who said the Koni/18"/eibach setup felt much better.
I'm near Bedford, happy to meet up for a demo if we can make timings work. Any excuse for a Z4 nerd out. :thumbsup:
