Has anyone had problems with major amounts of water puddling on the passenger footwell of a Coupe?
Found my floor pan drenched last night and looking under the carpets. The water is under the carpets, not on top of. After taking the windscreen scuttle pan off having removed the wipers, I can see the heater fan/element has a load of black mastic round it, as if it’s been a problem in the past for a previous owner. Anyone else had this problem?
The drain areas are clean although both little drain “cups” by the two wings seem to be very loose....maybe that’s the design??
Pictured below is the heater fan/element with mastic on it (left of photo).
I read previous posts and people have mentioned door membranes but I have discounted this, as I can actually see water trickling down the inside of the firewall behind the glovebox, when I empty a watering can over the windscreen.
Any advice appreciated, thanks, Jamie
