Hi guys this is my first post and I apologise because I know it's been covered but couldn't really find an answer. I've had the dreaded abs pump issue, less than 24 hours after picking up the car! Anyway have got it going into the garage next week and sending off the pump to ecutesting for a refurb, so the car will be off the road for a few days. (This forum was a great help in finding out about ecu testing!)
So I've read a bit more about common problems & the main one seems to be the rear springs. They're going to snap sooner or later & I'm thinking I may as well change the whole set while the car is off the road.
Which brings me to my problem. So eibach springs are the ones to go for, but different sellers advertise different drops in height with exactly the same part number, it ranges from 10mm-40mm. I don't particularly want to lower the car, as it's firm enough as it is. (I use this as my daily). Does anyone have the eibach springs fitted? (Part number e10-20-010-05-22) Has it lowered the car? If so is it too low? Currently mine has no problems going over speed humps or mounting curbs and I don't want this to be affected. it doesn't seem that eibach offer a set for my e86 that doesn't change the ride height.
The car has only covered 18k miles, how reliable are the shocks? Should I consider bilstein dampers as well? I read the b6 ones are an upgraded version of oem and don't affect ride height, is this even with the eibach springs?
Sorry I know there's loads of questions there, but I'm hoping someone can give me a short response and clear all of this up.
