E86 Slight Water Leak
Wigsters
Hi All
I have searched around in the forums but wanted to run my thoughts past you.
There is a slight water leak into the passenger side of my coupe, only noticed at the weekend as I took it out for a drive with the plan of putting the cover back in it this week as its dry enough to wash the car.
Anyway, it's not too bad and I think the leak is coming through the rubber seal at the front of the passenger door, exacerbated by the fact that our drive is very steep so water will definitely head for that entry point.
I have now parked the other way around and am making sure it's dry before I cover it but I wanted to see if I am missing anything in your opinion. I read a lot about door membranes, is that just an E85 thing?
Fixing this will be a spring job I just want to make sure I have looked at all of the options as to the cause.
