Hello,
Got a curious issue with my rear light cluster. Bulb warning came on and did a walk around and found it was the nearside foglight.
I examined the bulb and it was visually fine and worked on the other side.
I ran a code reader on the car and no errors, which is both great but not helpful. It is only a basic reader so I wonder if an indy could discover more?
I ran a continuity test on the bulb socket and the pins for the connector and pin is dead and pin 2 and 3 are dead on the connector itself.
I plugged the fully functional cluster into the nearside (faulty side) and the fog didn't work either.
I also plugged the faulty cluster into the offside (functional) wiring and the reverse light became the side light and the brake light became the fog (not sure how reliable this is as a test)
Does anyone have any experience of this type of gremlin?
NB Not sure if relevant but for context the bulb warning originally led me to the sidelight which I sorted, and then came on again shortly afterwards, so dunno if that did it as I did the bulb holder mod on the angel eye to swap out the broken bulb? The bulbs look different but I was assured T4W was the right replacement.
Might of always been the fog and I happened the catch the sidelight first as assumed it was that...
Bulb warning before all of this was intermittent and is now always on.
