Davemtkd said:Hi lads,
Newbie question. When did the N52 3.0L engines go from the grey (magnesium?) engine covers to the black plastic covers?
And did all the Z4 3.0si cars have the black plastic?
Mines an October 2006 build, E86 3.0si and has the black plastic cover.
Cheers![]()
Davemtkd said:And did all the Z4 3.0si cars have the black plastic?
Brouse said:If I recall, Black cover has plastic rocker cover with integrated CCV unit whereas Silver is magnesium with CCV unit sitting under intake manifold?
Smartbear said:Brouse said:If I recall, Black cover has plastic rocker cover with integrated CCV unit whereas Silver is magnesium with CCV unit sitting under intake manifold?
There’s engine differences as well, the black cover engine has narrower valve stems.
Davemtkd said:When did the N52 3.0L engines go from the grey (magnesium?) engine covers to the black plastic covers?
ph001 said:Smartbear said:Brouse said:If I recall, Black cover has plastic rocker cover with integrated CCV unit whereas Silver is magnesium with CCV unit sitting under intake manifold?
Thicker actually (6mm rather than 5mm), but I’ll let you off on this occasion :wink:
bg1 said:No Black Top fan boy ever mentions that the N52K is 'COST SAVING'.
