Basically the same but 5X the pricepvr said:Good result, not sure what a BMW version of that is though :lol:
I think he meant get the official OEM part installed.pvr said:Good result, not sure what a BMW version of that is though :lol:
Unfortunately I didn't get the time at the weekend to investigate where the strap was or if it was at fault. Would have been satisfying to have solved it..but heyho.j3nks79 said:Oh that’s an easy fix then. When you were getting no fault codes it indicated a lack of power to the starter. Hence why I thought it might be the ground strap.
Z4Mariner said:Glad you got it fixed ! On my US-spec E86 there is only one ground strap (other ground wires). I've had mine off to clean & tighten, and it looks like your perished one. For LHD cars it's engine-to-chassis at the right side engine mount chassis bracket. If it's in the same spot for RHD cars, the access may be a bit tighter.
Yes problem is now solved. No, it wasn’t the battery. It was the earth ground strap joining the engine block to chassis had corroded.wolfgangCoupe said:Did you ever solve this issue on this? Was it the battery that was causing the issue?
