Andrihallik
Hi fellow z4 owners! Sorry for long post... asking for some help regarding cv axles and part numbers.
Just bought the highest mileage e86 i could find and rebuilt the whole rear axle - new subframe, sand blasting, painting, all the bushings and bearings etc. Did not have any problems just looked like it would want some loving hand.
While installing the cv axles to the wheel hub assembly i used mallet to get them through so i could pull them with hub nut. - bad idea. Bent something from the other side so the grease splashes out while driving - the rubber area that holds grease in is not damaged and not leaking from there.
By vin code numbers for cv axles are 7566231 and 7566232. Impossible to find from Ebay and other sites from Europe.
But i could find a lot of cv axles with code 7541439 and 754143940 from Ebay and other sites - some sellers say that they wont fit but others say they will..
By researching i did not find anything - only that they are discontinued and that LK & D are the same.
Does someone have experience with something similar regarding part codes or should i keep searching for the correct codes?
Thanks in advance!
Thanks in advance!
