S sd_dracula Member Oct 17, 2013 #1 Anyone know how to replace this piece of trim? It goes under the speaker cover and door sill. Also cannot seem to find it on bmwfans.info Anyone know under which section it is?
E edd_jedi Active member Oct 17, 2013 #2 By replace do you mean remove? You just pull it, it is clipped on. It's easier if you remove the door sill first, which is also clipped on.
S sd_dracula Member Oct 17, 2013 #3 Yes but it seems that the huge plastic trim surrounding the speaker/sub behind the seat is also on top of it. Does that need to come out also?
E edd_jedi Active member Oct 17, 2013 #4 No it easily slides out from underneath it, I've removed it several times without removing the rear panels.
S sd_dracula Member Oct 17, 2013 #5 Nice one. So it's on those clips similar to the door panels that just pull out. The door sill is being replaced so that will be off anyway
S sd_dracula Member Oct 18, 2013 #6 I still can't find this part in the likes of realoem. Anyone know under which section it is? You'd think it's under vehicle trim.
E edd_jedi Active member Oct 18, 2013 #7 I can't find quite a lot of Z4 parts on RealOEM, been looking for the drop links for days!
S sd_dracula Member Oct 18, 2013 #9 Dealer came through, part no 5 below but almost impossible to tell from the diagram:
