Hello you lovely bunch! Looking for a bit of first hand advice from you on a couple of rattles. The car is a coupe (E86) but I think the rattle-fix I’m after will apply to E85s as well.
I've just sorted one of the rattles - probably the most difficult one I suspect – it involved taking off two pieces of trim behind the driver’s right shoulder – couple of piccies later in case that helps anyone other than me.
I’m after some help with the other rattle now.
I suspect will be easy-ish for someone on here. The door button seems to rattle a bit on poor roads or, at least, roads that make the car vibrate because of the poor tarmac. I think it is the door pin itself – i.e. the black plastic cover which protrudes and retracts when you lock the doors. I was thinking of wrapping some felt around the base of it or perhaps wrapping the inside of the (presumably) plastic tube it retracts into when you lock the door.
So the questions are:
- Is that the correct way of doing it – would you wrap the button or the tube?
- How do I access the base of the button or the tube – do I need to take the door card off?
- If I do have to take the door card off, are there any precautions to take with regards to the air bag? Can I just leave that in place by being careful?
Finally, I have one more rattle which I have identified. The cover for the B-pillar, which I took off when solving the first rattle, is attached to the metal B-pillar by two plastic clips. When I removed the B-pillar cover, there was only one clip there. I’ve heard of people buying these off EBay – so, would anyone have a spare one by chance. Piccy below.
Thanks in advance for advice and/or spare clip!
Stevo
Stevo
