E85 under steering wheel trim for cruise control stalk
ajs01
Hi does anyone have a spare under the steering wheel trim that accommodates the cruise control stalk ?
thanks in advance
thanks in advance
It is relatively straightforward to cut the marked section out of your existing one.
I have one but with a small hole I drilled near the ignition cutout (when I was experimenting with my heated steering wheel switch)…
Could put a rubber bung in there or cover it with something else. Can have it for free if you wanted to just pay postage? I ended up cutting out another one, which was easy enough with a dremel, so you should be fine if you went that route :thumbsup:
thanks, I am going to try and cut it out - if I make a pigs ear of it I will give you a shout! - kind regards
