If you swap the lines round on the pump, you will also need to swap the two electrical spade connectors too, otherwise your switch will work in reverse.Your pump head may be starting to struggle
Easy fix.
Swap the power and hydraulic lines around
It will go down normally with gravity helping it and back up at a good speed
