E85 Roof latch releasing when driving
Lano1978
 York
Good evening fellow Z4 enthusiasts . I have an issue with the roof . When the roof is opened everything works as it should and the roof latches correctly after a drive the roof light begins to flash. If i press the roof open button quickly enough the light goes out . if I don't the roof refuses to close and I have disengage the motor and close it manually . Has anyone had similar issues and how did you solve it ?Bimmer Z4.jpg
You may get better help posting this in the correct forum section - try the general discussion for E85/E86
