I had problems with these getting blocked a year ago and damaging the roof motor. The main dealer took the roof off, cleaned the drains and renewed the motor. I want to make sure the same thing doesn’t happen again. I know how to access the bottom part of the drainage channels and have removed the rubber bungs. The passenger side top drainage hole has the motor sitting directly above so you can’t stick anything down to clear it. I was thinking of getting an attachment kit for my vacuum cleaner which has at a thin tube and several very small nozzles. Does anyone think it would be possible to clean a build up of dirt/leaves etc from around the base of the motor and clear this side of the drainage channel.
