E85 Rear wing removal : job
goldbcfc
 Birmingham
I need to change a rear wing on a E85, all bolts are easy to access apart from one which seems to be inside the boot. Has anyone got advice on this as ive had two attempts at releasing the alluminuim roof bracket. This i supposed to allow enough space to get at this last bolt holding the wing on.
http://www.z4-forum.com/forum/viewtopic.php?t=77653&start=15
https://www.youtube.com/watch?v=__DMR3QulSw
I changed drivers side rear wing a little while ago. Instead of removing half of the roof to get to the bolt under the back of the roof. I cut the old wing out from the top with a new cutting disc on the grinder and trimmed the tab off the replacement wing before fitting . added a good size blob of sealant to the body where the trimmed tab is and it worked a treat :cool:
