longleydel
SonnyA85 said:If you find it's draining really fast within a week and drops below 80% from full within a week and when the alarm isn't on full mode then I'd see if someone with a decent scanner can run a test for you.
I have a Carly if you are anywhere near Glasgow I'll be happy to check for issues I'm home most of the time anyways and I can even potentially test your battery using my smart charger and see what it says.
Hope you get it sorted. It could be the alternator if it's not the battery. It's not being charged when driven and you are just depleting the battery more by starting the car and using it.
So I'd Google how to test the alternator and search on here as well and YouTube. That could be the issue as well. Unless your mechanic already tested the alternator
Hi, thanks for your message. Its great that the Forum attracts many knowledgeable people willing to help and advise.
Thank you for your kind offer, unfortunately I live in the south east corner of England.
The alternator was tested by the auto electrician last summer and found to be working normally. My battery tester has the facilty to check the alternator and run a ripple test. I did this more recently and everything was normal.
Thanks again.
Derek
