E85 facelift interior bits
Dann2707
Hello,
I'm after these bits please
Xenon headlight switch unit as mine is cracked (as I understand it this unit can't be eaisly swapped over as it control the mileage but wonder if I can swap panels)
Driver side vent unit
Cup holder or cup holder blank
Thank you very much
I think I have the vent surround and cup holder bit in my shed. The vent surround just clips on, so should be able to replace it easily with the one I have.
I'll have a look for you.
Found these bits. Any good to you?
The cup holder fascia has some marks on it. I've tried to capture them in the photo.
Dann2707 said:
Hello,
Thank you very much
Your right the light switch can't be swapped over without coding, however the front plastic trim of the light switch does just unclip and is easily swapped over. never looked at the fog light buttons but hopefully the same will apply.
Thank you for taking the time to take the photos and reply.
I ended up buying some on ebay the other night. Thanks again buddy
MACK said:
Dann2707 said:
Hello,
Thank you very much
Cheers Mack, I'm struggling to find the front fascia which is the same as mine (auto lights with no headlight level adjust) but I'm constantly searching ebay.
Thank you for the reply
As mentioned on Facebook, I'll check my stash Saturday (Well, probably late Friday night once I'm home after Cinema) I'm sure I've got one :thumbsup:
(You're correct too - it's only the plastic trim that's really of use to you. LSZ's need coding, as they store milage etc. Milage is stored in multiple places actually... like EWS, Clock (obv), and LSZ and poss another module or 2)
