My z4 was standing for a while when I tried to start it ,I found the Battery low voltage ,I connected my charger to the points provided in ehe engine bay and charged the batt ,now everything work,engine crank but will not start, I checked all fuses all ok ,need help Please :x
Welcome to the forum.
Hi, you must be missing either sparks or fuel to have a non running engine-try taking a plug out but reconnecting the coil and cranking to see if it’s sparking.
If it is, check for fuel
What's the battery output? It may be that yes it's charged but battery is on the way out and it's not putting enough into the starting system. Is it slow to turn over?
It crank strong ,I even connected a spare battery to the terminals provided in the engine bay ,I checked the 5 fuses in the engine bay inside the black box as well. everything els work fine ,tried spare key no help.
Would be handy at this stage to get the codes read and see what the car is saying. Post on here to ask if anyone has a code reader and are near to you. Lot of very helpful people on here.
Try using the other key to see if it will start. The key battery is charged by the car and it may not be have enough charge to register with the security system
Try disconnecting the air intake, and have someone spray a little WD40 into it as you crank, IF the engine fires, then you know you have a spark. HOW have you checked the fuel rail pressure? There is a test nipple on it for a gauge on 6 cyl cars, not sure about the 4's.
