MACK said:b19rak said:After much bending and flexing i've got it done. The bolt at the front is pretty easy to get to with an 8mm socket and small extension. The one at the back is a little b*stard and requires being on your back in the footwell in crab formation. I found that a previous owner has already done this as pencil marks showed it had been moved about 5mm. I did another 7mm. The ring was tight so i had to use a screwdriver and hammer to tap it CW. Has made a really positive difference straight away. The steering feels nice and positive now but a little floaty at higher speeds. Not sure if i should tighten a bit more or leave it. What do you guys think?
It might be worth backing it of 2-3mm just to see if its better at speed. Personally I know it would do my head in if I didn't try it to see if made all the difference.
Thanks for the reply. When you say backing it off do you mean move it back 2-3mm? Wouldn't the looseness i had before come back?
