E85/E86 master cylinder to ABS pipe / hose
Hello,
I don't suppose anyone has a brake pipeline w/pressure hose for a Z4 E86 (E85 2.5/3.0L parts work also) lying around. It's the part that connects the master brake cylinder with the ABS pump and is M12 to M12 connection. There are 2 hoses - i need the back one closest to the bulkhead.
It's similar to part 1 in the below, but the correct RHD part # is 3432 6774389 and old part 6769816.
https://bmwsupply.co.uk/part/details?series=e86&typ=du51&og=02&hg=34&bt=34_1499&view=btdetail
Mine has been accidentally binned and part is on back order!
Thanks,
Liam
liamconnolly said:
Hello,
Thanks,
Liam
I have a 3.0i that I am stripping for parts - I could see if it has the part you require. Is it the full hose you need?
That would be great! Yep, it's the full hose - I think it is plastic coated steel, narrow gauge pipe with a braided flexi hose in the middle and m12 connections at master and abs pump ends.
What are you offering for it? Ill try get it off the car
