Yeah, that's my point, after years of driving RWD cars I'm much more into the brake hard before the corner and select the correct gear to drive through it. The older auto box is too slow so you're past the apex and still waiting for the drive. It's the 'let the box sort it out' bit that leaves you hanging.Rockhopper said:You need to go into the corner a bit faster and brake harder into the corner then plant your foot into the carpet on the way out and let the box sort out which gear it wants to be in.
Sounds as though I need to have a go in one to see for myself. I love a gear change, but I also love relaxing in Friday night stop-start traffic on the A2 :lol:Zedebee said:Hi Inkey$, the auto box took a bit of getting used to, but is it still fun? Yes. I am not the raciest driver, but I do like to put my foot down at traffic lights and let the three litre lump do it’s thing; and the approach to corners is solved by selecting second or third in manual mode. It’s not as sharp as the autobox in my former GT86, but it’s good nonetheless, seems to be reliable, and is a godsend in traffic. You are welcome to try mine if you are in the area.
Very interesting. So the pre-facelift can be wired up with paddles if required?DMike said:I have the pre facelift auto, with retrofitted paddles. Or ”retrofitted”, as there never were paddles available from facory but the circuitry is very simple. Combined with the 3 litre engine the box is plenty fast and fun, with good 0 to 60 times by just using the first two gears and you could drive through most corners in 2nd or 3rd keeping the revs high. Don’t do tracking, so cannot comment on that.
Yes it can. I think there has been some threads on the forum about this. The gear stick’s up/down circuitry is just a simple switch with three wires. A parallel connection is run to the steering column’s clockspring and from there to a smg or post facelift steering wheel with paddles. Most pre facelifts will need a new, smg or post facelift clockspring. Did mine some 15 years ago with a set of parts and instructions bought from Mr. Paddleshift — which may be out of business nowadays. The installation wasn’t difficult.inkey$ said:Very interesting. So the pre-facelift can be wired up with paddles if required?DMike said:I have the pre facelift auto, with retrofitted paddles. Or ”retrofitted”, as there never were paddles available from facory but the circuitry is very simple. Combined with the 3 litre engine the box is plenty fast and fun, with good 0 to 60 times by just using the first two gears and you could drive through most corners in 2nd or 3rd keeping the revs high. Don’t do tracking, so cannot comment on that.
As Dmike says, yes it can. You will need the paddles or steering wheel complete with paddles from a pre-facelift SMG (same as mine) and a few other parts, connectors and cable. This video shows how : https://www.youtube.com/watch?v=yQlL5htuY7k&feature=share&si=ELPmzJkDCLju2KnD5oyZMQinkey$ said:Very interesting. So the pre-facelift can be wired up with paddles if required?DMike said:I have the pre facelift auto, with retrofitted paddles. Or ”retrofitted”, as there never were paddles available from facory but the circuitry is very simple. Combined with the 3 litre engine the box is plenty fast and fun, with good 0 to 60 times by just using the first two gears and you could drive through most corners in 2nd or 3rd keeping the revs high. Don’t do tracking, so cannot comment on that.
