Thanks for responding. Yes, that was my first instinct, however I’ve seen others saying you only need to add around 500ml otherwise you overfill.Mr Tidy said:I've always understood it means you need to add a litre to an N52 engine.
If BMW are happy for it to run 1l low before you top up, then putting in 500-750ml means you have peace of mind that it's not too full but it is still full enough.inkey$ said:Thanks for responding. Yes, that was my first instinct, however I’ve seen others saying you only need to add around 500ml otherwise you overfill.Mr Tidy said:I've always understood it means you need to add a litre to an N52 engine.
