I have a 2003 3.0 that had an automatic trans- I drove maybe 300 miles on the auto trans before it started to slip bad enough to fix. Important to note the car drove smooth with no vibration when I bought it, Had a dead battery and previous owner cited transmission problems but healthy motor.
I swapped it with a manual trans from donor car with 190k
I replaced all seals in motor & trans, rear main, crankshaft, input & output shaft seals
replaced engine mounts and trans mounts with OEM+ 80A engine mounts from FCP euro link
I replaced center support bearing, and guibo flex disc with OEM parts
Because it was a manual swap, I had to use the manual car's driveshaft, and I am positive I did NOT put the driveshaft back together in the same orientation, my pen mark line rubbed off.
I have not replaced the wishbones, or differential bushings.
the chassis has 135k miles, replaced all 4 struts too-
The car rode smooth with the automatic trans,
but with the new MT and driveshaft I have a heavy vibration between 15-40mph
it is most noticeable between 2-4k RPMs
it vibrates in neutral when I rev the gas
vibrates under load, acceleration & braking during the specified speeds & RPMS.
Any advice on balancing a driveshaft? Anyone have a photo of their driveshaft off a manual car to display how it connects together?
