I have available a 2.2L M54 engine with roughly 100k miles for sale. I’d be willing to let it go for £100 ONO. I have all the ecu, modules, dash, key etc. that you need available too if you require so that you can do a straight swap with no coding required at additional cost.
I also have a 5 speed gear box with similar mileage and only asking £50 for this.
Finally I have a full exhaust system that came off the same M54 engine. I’m asking £150 for each manifold and £150 for the full section form the manifold back including back box. Or £400 for full set.
Please note the engine and gearbox came off a converted Z4 race car and although the engine and gearbox run and work perfectly I want to fully disclose what condition they’re in. Note; the engine only covered roughly 1,000 miles on the race car and all previous use was on the road. Only reason for removing is because I’m upgrading to a 3 litre engine with 6 speed gear box.
I also have a barely used lightweight flywheel and clutch for the 2.2 that I will be listing on the forum for £350.
Please don’t hesitate to contact me for more info.
