DMC63 said:I've got 15mm back and 10mm front. 12mm on the front of mine would have rubbed when driving with a bit of 'zest'I've lowered my car with the Bilstein B12 kit, so maybe if your running on standard springs 12mm may work. Best to be sure before you buy any.
Good luck![]()
AC5L4T3R said:DMC63 said:I've got 15mm back and 10mm front. 12mm on the front of mine would have rubbed when driving with a bit of 'zest'I've lowered my car with the Bilstein B12 kit, so maybe if your running on standard springs 12mm may work. Best to be sure before you buy any.
Good luck![]()
Interesting, maybe I'lll go down that route then because I'll be lowering it too.
AC5L4T3R said:At the moment I have 103's
Player 1 said:I've got a H&R set of 15mm and 10mm spacers that came off of my old 3.0i if you're still looking?
That car was fitted with 107 Ellipsoid alloys and Eibach springs after one of the rear's broke so was slightly lower than standard, personally I wouldn't have wanted to go any wider than 15mm at the rear for fear of rubbing.
