e46 m3 seats in e85
imp75
Hartlepool
would it be possible to fit these with a fairly simple plug and play - ie will the heated m3 seats be operated from e85 switches, and more importantly will the m3 seats plug into e85 wiring harness without modification?
secondly does anyone know whether my 2005 2.0 pre face lift be prewired for electric seats? i have manual at the mo? and again, if so, will the m3s electic movement be capatible without modification? cheers.
I think this may have been asked before but not sure anyone has done it, so may not know...
Not sure if the seats physically fit? Two things to check there (I think)...
The rails - distance between centres of the bolts along the rail, and the width.
Seat width, not sure if the E46 is any wider, in the cabin, but worth checking the room from the inner runner to the centre console.
With regard to the wires, have a look on RealOEM at each car and see if the connectors are the same, if so you may be in luck. Then get a look at the E46 switch panel (or owner's manual) and make sure the operation is the same - the E46 is an older car and may use a slightly different system there. Then, all being well, have a look at the WDS (there's a link through from my signature) and check that the signals are the same for the seat functions - power and heating... or that they are using the same technology.
Actually, see about reverse engineer the solution... check the E46 forums and see if anyone has fitted the seats... you could try searching from something around the steering wheel and M3, we had someone from an E46 M3 forum on here asking for steering wheel measurements. Try PMing them for the measurements above, they may return the favour.
ADD: I'm quite nerdy so if no one comes forward with any better info am happy to help with the WDS stuff.
Thanks pawnsacrifice! Plenty for me to get my teeth into! Not sure where to begin but once I'm home ill have a nose around the suggestions you've made. To be fair its not only the m3 seats I'm interested in it also apply to one series sports seats too....... which sound like they may be more inline with requirements being slightly narrower and more modern tech.
