CrazyBaptie said:I think I am going to go with the ones you have davros. Thanks for the help guys
That's excellent Dave thank you.davros said:Hi Leesfarm07,
The part numbers are 10386174 & 10385983. I got mine from GM parts direct, but I’ve since seen them advertised on eBay. It would be worth checking to see which one offers the best postage rates.
They totally transformed the seats once fitted and imo are better than the seat belt holders on the standard Z4 seats.
Dave
Leesfarm07 said:That's excellent Dave thank you.davros said:Hi Leesfarm07,
Dave
I had a set from the BMW dealer but they were an open ended sort that allowed the belt to just slip out all the time
I'll take a look see if I can find them![]()
David (Leesfarm07)
Dave
David (Leesfarm07)
hi do those prices include import taxes ??CrazyBaptie said:Leesfarm07 said:That's excellent Dave thank you.davros said:Hi Leesfarm07,
Dave
David (Leesfarm07)
Iv just ordered the GM ones from the USA on eBay - were the best price I could find and the same price as getting the OEM ones. Here is the links if your interested.
https://www.ebay.co.uk/itm/BRAND-NEW-GENUINE-GM-OEM-SEAT-BELT-GUIDE-10385983/232888858289?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
https://www.ebay.co.uk/itm/BRAND-NEW-GENUINE-GM-OEM-SEAT-BELT-GUIDE-10386174/362444477954?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
bz4kev said:hi do those prices include import taxes ??CrazyBaptie said:Leesfarm07 said:That's excellent Dave thank you.
David (Leesfarm07)
just interested,so what was the total with everything added for the 2 items ? Just being nosey really as I am really happy with mineCrazyBaptie said:bz4kev said:hi do those prices include import taxes ??CrazyBaptie said:Iv just ordered the GM ones from the USA on eBay - were the best price I could find and the same price as getting the OEM ones. Here is the links if your interested.
If you go through to the basket it will show you the taxes - its through an eBay global shipping program
bz4kev said:just interested,so what was the total with everything added for the 2 items ? Just being nosey really as I am really happy with mineCrazyBaptie said:bz4kev said:hi do those prices include import taxes ??
If you go through to the basket it will show you the taxes - its through an eBay global shipping program![]()
davros said:Hi CrazyBaptie, when I fitted mine I swapped over the 2 base rails from the seats to retain the Z4 seat belt fastenings. I also used the seat belt occupancy sensor from the original Z4 seats.
Good luck
Dave
davros said:The sensor is located at the rear base of the passenger seat. I’m not sure if the E46 sensor works and might cause an air bag warning light.
The sensor looks like this:-
davros said:Did you disconnect the battery and wait 30 minutes before unplugging the seat power connector? That can also cause an airbag warning light if you don’t disconnect power 1st. Hope you get it sorted mate.
CrazyBaptie said:davros said:Did you disconnect the battery and wait 30 minutes before unplugging the seat power connector? That can also cause an airbag warning light if you don’t disconnect power 1st. Hope you get it sorted mate.
Yeah I left it, I tried to swap the sensor over but the blue plug on it is different on both?! The one on the M3 was also plugged into a blank did you have this?
davros said:CrazyBaptie said:davros said:Did you disconnect the battery and wait 30 minutes before unplugging the seat power connector? That can also cause an airbag warning light if you don’t disconnect power 1st. Hope you get it sorted mate.
Hi mate, there should be 2 cables going into the sensor. 1 wire from the sensor mat coming from the rear of the seat and the other cable going into the main yellow connector plug.
You will need to remove the M3 sensor AND the cable & connector going into the main yellow power plug beneath the seat and replace them with the Z4 one. To remove this cable you will need to slide back the black part of the main yellow plug and the occupancy sensor connector should then slide out. The z4 one should then slide in. (The occupancy sensor connector which fits inside the big yellow plug should be the same shape for the M3 & Z4).
You will then need to unplug the occupancy mat wire coming from the rear of the seat from the sensor and plug in the Z4 one.
To remove the actual sensor, you will need to twist it 1/4 or 1/2 turn and then pull it from the seat base.
I hope this makes sense. It’s quite difficult to explain.
(I’ve attached a picture of the yellow plug with the black top slid open, ready for the connectors to be pulled out)
