P PAH Member Mid Wales Jul 8, 2020 #1 Have the dreaded 3 yellow lights which come and go. Went to a local garage who says it’s the ABS pump I saw the errors myself. Who refurbs this unit?
S sw4nny Senior member Barnsley Jul 8, 2020 #2 Is it the pump or just the sensors that need replacing?common fault.
W Weston Matt Member Cotswolds Jul 8, 2020 #3 I had 2 lights come up. I cleaned the abs sensors on the rears and the lights have gone - for now anyway. If you have been tinkering around the sensors, they may need a clean
P PAH Member Mid Wales Jul 8, 2020 #4 I’ve cleaned all 4 sensors as faults were showing. Today test drive car hit brakes hard and it locked up no ABS Local garage says pump I saw it on his laptop
D Danglesberries Member Jul 8, 2020 #5 so, you need a new pump then? local garage must be cheaper than stealers?
Mr Tidy Moderator North West Surrey Staff member Site Supporter Jul 8, 2020 #6 If it is the ABS pump ECU Testing re-engineer them:- https://www.ecutesting.com/ Luckily I've never needed to use them, but I'm sure I've read good things about them on here.
