Drivers window switch replacement
Morning all!
The driver's window switch on my Coupe 3.0si has gone very "flappy" and ready to break off any moment - its had a lot of use over the years. Can I replace just the switch or is it the whole door module? No folding mirrors, photo below.
Is it an easy process to pull the old one out or do I have to take the door off and detatch airbag wiring etc?
Any part numbers, help etc would be appreciated
Cheers!
Chris it's really easy.
Trim tool under the front edge of the trim and lift it. Then it should lift out as one unit, but there is a small projecting part at the rear so move it forward a little bit as you lift.
Then just two plugs to undo.
I've got a replacement one here as it happens.
I'll send you a Whatsapp.
Take it to bits and give it a good clean. Then when satisfied plug back in, if it works as should, well done, if not take Martin up on his offer. Mine packed up a couple of years back so did this and has worked perfectly ever since.
Cheers, tug :thumbsup:
I have a spare one I bought to replace mine but was able to fix mine so never needed it. If it any use lemme know.
Just pops out. 2 mins would swap em over.
