Driver's side front wing - titan silver (damaged but repairable)
Free as long as you're ok to pay for P&P. Was planning to scrap this but as it is fixable, I thought it might be of use for someone.
Wing was damaged by someone doing an appalling job trying to park next to my car. There are 4 impact points as seen in the photo below - 3 minor and 1 serious.
The photo is HDR so shows the locations well, but in normal light conditions the two impacts on the main body of the wing are barely noticeable and access to the rear of the wing is easy, so fixable. The impact on top of the arch is a bit more tricky to get to from behind; no paint damage however, just very fine scratches that would likely buff out.
The most serious damage is to the right-hand side of the wing, where the panel was slightly crushed and the paint damaged; a decent panel beater would be able to get it sorted. There is also some minor paint chipping on the very bottom edge - no sure where that came from as it was on the car when I bought it. There is zero rust on this wing. and the rest of the panel's paint is in good shape - no scratches or stone chips.
The wing does come with the insert for the indicator, but no clips/fasteners as I needed to use them on the salvage wing I bought to replace this one. Also, one of the metal tabs for one of the bolts on the bottom of the wing had to be cut off - the bolt had a weld-dimple on it and it was impossible to remove cleanly without cutting the tab off. However there are 2 tabs on the bottom of the wing, right next to each other - the other one is fine.
Wing is located in Aberdeenshire, but happy to courier if you pick up the cost.
Would be good for someone to practice their machine polishing and panel beating skills if nothing else.
