bmwmasterrace
Reversing in the garage and I hit the side...it's just dangling now...fml
What should I do?
So pissed.
What should I do?
So pissed.
Citation 650 said:If you do a search for "side mirror" you'll see what others have done.
JohnnyC said:Oh. and a more recent post (same guy, with actual repair pictures)
http://www.z4-forum.com/forum/viewtopic.php?f=3&t=65953
(If you dont already know) I would recommend using coarse sand paper (220 grit) to rough up the surface. Then make sure you clean everything very well. Follow the instructions on the epoxy very well and make sure you cover the entire joint. Also apply it to as much surface area as possible.
As an experiment, you can also try adding some wire mesh as reinforcement. The glue will break at the weakest point so the reinforcement helps spread the load and help hold it together. Like this diagram:
= G o G G G G G G G G G
= G o o o o o o o o o o o o
= G G G G G G G G G G G
==========x========== <<< the part (x is the break)
= G G G G G G G G G G G <<< the glue/epoxy
= G o o o o o o o o o o o <<< the mesh. You can shape it ahead of time so its quicker to add
= G o G G G G G G G G G <<< then some more glue over it. Make sure its cover
= G o G
Yep, looks broked to me - however you say it :thumbsdown:Stu Boy said:Bummer you broke it.
