My 2007 3.0i roadster driver side hood latch is not latching. I removed the latch, cleaned it thoroughly and lubricated it and tested it numerous times by pressing into the latch with a Phillips head screwdriver, and it would latch and release every time. I reinstalled the latch and shifted it left and right and would still not latch. I have looked at the metal loop that’s attached to the hood and wondering if it is somehow adjustable. I need it to be at a bit lower position so that it will fully drop into the latch assembly. The hood mounted latch loop does have a Phillips head screw on the inboard side of the plastic mount, but the screw itself is plastic and when I tried to unscrew that the screw immediately began to waller out.
Suggestions?
Suggestions?
