OK so did some work on the car yesterday which meant disconnecting the battery. I now have a few gremlins, namely my remote roof module doesn't work, nor can I raise the drivers window when locking the car using the key. I have a feeling this maybe linked to the GM5 module and the relays packing up.
About two years ago when it snowed the central locking failed giving typical GM5 module failing signals. However after then it's been fine but I guessed only a matter of time till total failure.
So my question is with the car unlocked if you use the key what does yours do, as mine only locks the driver door leaving the passenger door and filler cap unlocked.
I'm guessing this is also why my remote roof won't work as that is linked to the central locking.
