Hi, I have a 2.2i e85 roadster. A few weeks ago when I opened the car and the driver side door remained locked so I had to use the other side to get in. After inserted the key and moved down and up the windows the door was okay again and the issue haven't come back since then. Yesterday when I tried to get out of the car with windows down it didn't let me out, I had to move up the windows to get out. Since then, I cannot open the drivers door from outside. From inside after I get into the car from the passenger side and insert and move a little bit the key the driver side door can be opened from inside, but from outside it remains stuck. I read the fault codes, please see the attached image. After clearing the codes the 07-[007] Anti-theft alarm system error message remains there, the others disappear. The alarm system doesn't work, I tried locking the doors while sitting inside. Turning off the DSWA doesn't solve the issue and it hasn't been working since a long time. Of course I tried locking and unlocking with key and remote as well, same result.
Can it be related to the GM5 module? Seems like not a physical issue. Thanks in advance!
