Jl-c said:metal
Liam22 said:Or ask yourself how much you value the airbag off warning light.
griffnut said:I've done it on one of m old cars, as said before start with a small drill and work your way up. I used masking tape to protect the Black Piano Surface from scratches that could occur during the process.
Take your time and all should be fine.
gmorris03 said:griffnut said:I've done it on one of m old cars, as said before start with a small drill and work your way up. I used masking tape to protect the Black Piano Surface from scratches that could occur during the process.
Thanks very much! Now I just need to work out how to get the old dash trim off.......
srhutch said:gmorris03 said:griffnut said:I've done it on one of m old cars, as said before start with a small drill and work your way up. I used masking tape to protect the Black Piano Surface from scratches that could occur during the process.
You’ve got to remove the centre console. The trim piece is held on by about 30 screws.
