Draughty Armrest,,
RustyZ4
Veteran
 Maidstone, Kent
I have noticed that when I crack my drivers window for a bit of fresh air while driving, I get a heck of a draught coming from under the door armrest sort of into the door pocket , on further inspection there are several rectangular cut outs that the draught is coming out of.
I have searched but cant find if there are any "bungs" to fit in this, does anyone know if there are and where I can get them?
I have put a bit of cloth black tape over them for the moment, as something like this starts to get to me :oops:
When you remove the door trim panel from the front door there should be a plastic sheet beneath it. Might be worth popping the panel off and having a peek inside. It may well have been left off if DIY work has been done on the car in the past. It is a vital part of the car as it keeps any damp or draughts inside the dor and away from the expensive fascia panel. Most vehicles have this.
Item number 8 on this illustration they call it insulation..
https://www.realoem.com/bmw/enUS/showparts?id=LM32-EUR-06-2009-E89-BMW-Z4_23i&diagId=51_7270
Cheers for that, I will check it out
