Wondering if anyone can help me out here.
The passenger door on my E85 doesn't open (and my window won't go down). I've read this can be an issue with them so decided to kill two birds with one stone and investigate the mechanism and drop in a regulator repair kit too. The door not opening has happened before but I opened it and just worked the mechanism a few times and it fixed it. I'm hoping this has just happened again and it needs some proper cleaning.
Anyways today I tried to access the goodies by trying to removing the door card/panel. I've removed all the screws in the door (behind Airbag logo, two in the door pull handle and one behind the door handle itself). I also removed the trim bit in the top corner with the small speaker in it.
But now I'm stuck. All guides I've found show removal of the panel with the door open, but how can I get to the door mechanism with the door closed? From looking at the way it's put together I just can't see how I could remove the door panel with the glove box and the passenger seat in the way.
Any advice would be greatly appreciated because not having a window that opens is one thing, but having a door that doesn't open is just too annoying for me.
Thanks!
Thanks!
